Updrilled the RH rib attach angles at the spar sta 6 with #12 bit for the AN3 bolts. It was much easier to updrill the spar and angles if the webs are not already attached to the angles.
Updrilled the rib doubler gussets and spacers at sta 7 with #19 drill for the AN525-832R18 screws.
